By any chance have you looked at the photos here: www *dot* engadgethd *com* com/2006/01/14/creating-your-own-component-cables/
The dimensions to which the cable is cut are extremely important and care must be taken not to cut into the center dielectric or to cut any of the center conductor. (Which tool are you using, by the way.) Notice how the center pin is resting on the dielectric so no cable is exposed. The recomendation to give the center pin a tug is a good one; you may have to adjust your crimper to get good results. Note that because the Paladin die set is narrower than the Canare, you have to crimp the ring twice. All in all, the article I've linked to is about the best write up I've seen.
Good luck,
Sam
