j_garcia said:
The rise at the tuning frequency is the same whether it is front or rear ported, given the same speaker and same tuning, it should be no different. Audible port noise may be an issue with a front ported design that is not well implemented, but with most bookshelf size speaker's tuning that generally isn't an issue.
Bass with sealed is tighter because of the spring effect that the enclosure lends to the driver and while the bass can extend relatively low, most sealed designs tend to lack the same kind of oomph at the lowest extension that a vented design often yeilds. Sealed designs also tend to both require more power to drive, but also can take more power.
There are fewer companies making sealed designs these days, but there are still some out there. NHT still produces sealed speakers and I like their sound.
The SVS bookshelves are sealed too.
I've owned front ported and rear ported mains (although, not the same models, or companies...) and I think the difference is there. The rear ported ones were towers, and the front ported ones are my Energys.
Obviously, my towers had more slam and extension (6 1/2 inch woofers) but the bass sounded different. I don't want to use loose terms, but it sounded warmer, a little muddy (but, some of that could be the speaker itself).
I know I have heard nicer sounding rear ported towers, but I still feel they are too room reliant, thusly making them more difficult to place. My C-1s and my C-C1 sound great right where they are, but the towers and my old rear ported center didn't. The vocals didn't have the body that they do now, sounded dry.
I don't know, I'm rambling. Maybe I'll pull out my rear ported rears and A-B them with my Energys.
SheepStar
