From Amplifier to Speakers and subwoofer matching
Z
Zakir
I have the below specification HTS and i would like to take an professional advise, is this specification is perfectly matching or do i need to make any changes apart from settings....
Denon X2100W
impedence 4-16Ω
frequency Rep 20hz-20khz
front L+R (95w+95w 8Ω/125w+125w 6Ω)
center (95w 8Ω/125w 6Ω)
surround L+R (95w+95w 8Ω/125w+125w 6Ω)
surround Back L+R (95w+95w 8Ω/125w+125w 6Ω)
Klipsch quientet 5.0
impedende 8Ω
Frequency Res 110HZ - 23kHZ
Watts-cont/peak 50Wx4/200Wx4 -all sattlite
75W/300W - center
Jamo-C605 full range one pair
impedende 6Ω
Frequency Res 37hz -20khz
Watts-cont/peak 140W/peak 200W
Subwoofer-Jamo 360 one piece
Frequency Res 28hz -200hz
crossover 40hz - 200hz
Watts-cont/peak 360 Watts
SubWoofer-Jamo j10 one piece
Frequency Res 31hz -120hz
crossover 40hz - 120hz
Watts-cont/peak 150W/peak 300W
tyhjaarpa
tyhjaarpa
I'm a bit confused of your post.. Are you buying some equipment? Can you answer to these questions:
What you have now?
What are you trying to achieve?
What size your room is?
What is your budget?
markw
If I read your post correctly, all your might need is a male/female/female "Y" connector to connect the two subs to your receivers subwoofer/LFE output. If it has two outputs, you don't even need that.
how it will sound I can't say, but it will work.
jonnythan
jonnythan
You don't want to try to mix those Jamo tower speakers with the Klipsch Quintet center speaker. You should try to find a Jamo C60 center.
I'm not sure you want to use both of those subs at the same time, either, but your receiver does have 2 outputs so you could try it.
Z
Zakir
this is my 7.2 system with audyssey calibration and it is working fantastic without any problem,
my question is it ok keeping two different specification and different type (downfiring and frontfiring) subwoofers for clean even Bass following other requirements like room dimension and acoustic treatment…
my front pair is also full band so shall I consider this will also help me in clean even bass…
i read lot of stuff about multiple subwoofer setups...and i did all possible scenarios....
still i am not satisfy with low frequencies (bass)..
tyhjaarpa
tyhjaarpa
You need a better sub then I suppose. You could try to sell those Jamo subs and buy a sub that performs better.
Z
Zakir
let me know more technical answer why my sub woofers are not good ??????? what is your suggested sub woofers.
tyhjaarpa
tyhjaarpa
They are quite small and not so powerful subs. And can't go low enough.
What is your budget? Where are you from? Room size? Do you want 2 subs or are you fine with one? Answer these questions and we can give you suggestions.
Z
Zakir
My budget is two sub woofer under $1000, i am from saudi arabia, L=14 W=15 H=10...
My front pair is full band, shall I consider this will also help me in clean even bass…?????? if yes then in that case do i really need two sub woofer??
TheWarrior
TheWarrior
Start with one powerful subwoofer. The one you have is not capable of playing much below 40 hz. And what it does play, I suspect would be described as 'muddy', or 'lacking definition'.
tyhjaarpa
tyhjaarpa
I would go with one sub. You may add another later on if you feel you really need one. Do you have any online shops out there where we could see what is available for you?
From google I found that Wadi sells SVS out there and you can find one contact directly from SVS site as well. PB 2000 for example would be good option and in US / Europe it is within your budget and would perform well. I would contact those retailers and ask for price they can offer for you.
https://en-sa.wadi.com/svs/?q=subwoofer&dir=desc
http://www.svsound.com/pages/international-dealers
Z
Zakir
thanks for your support
there are two model sealed and ported which one should i go..
tyhjaarpa
tyhjaarpa
Ported (PB) will have more low end extension, so you will get deeper bass for movies when sealed (SB) is more controlled and often called more musical. Both are good subs, PB will require more floor space when SB requires less as it has smaller enclosure. If you want more and deeper bass go with PB but if you want more controlled bass and smaller size then SB is better pick.
jonnythan
jonnythan
Kind of a semantic issue. Sealed technically has more low end extension. Ported will have higher SPL down to a certain frequency, then response falls to essentially zero. Sealed rolls off far more slowly and evenly. Sealed will be audible, but not necessarily powerful, at lower frequencies than ported.
tyhjaarpa
tyhjaarpa
But isn't it the SPL you want for movies? :)
jonnythan
jonnythan
Depends on where you want the SPL. Sealed subs have lower usable output, but ported generally have more output in the 20-40 Hz range, which may be important to you. After having owned both, I personally prefer the natural roll-off I get with a sealed sub. It seems more.... I dunno, polite. I don't want to think about my speakers while watching a movie, and ported subs seem to call a little more attention to themselves somehow to me. Sealed sounds a bit tighter and quicker.
tyhjaarpa
tyhjaarpa
I myself have sealed sub as well.. How ever I have not met the problems you describe with ported subs I have listened more to.
