Friend Loves my 12" Rythmik. Wants similar under $600. Thoughts???
bizmord
bizmord
Hi guys,
So a friend of my always compliments how great my Rythmik 12" Sub is performing in movies and music. He currently has a Yamaha sub that he bought for around $300 5-7 years ago. His biggest complaint .... "it doesn't go low enough".
I am thinking that he can do great with
SVS PB-1000
http://www.svsound.com/subwoofers/ported-box/pb-1000
In terms of footprint ... He is somewhat limited in sub width but OK with any depth.
Any suggestions?
thank you
billy p
billy p
The PB1000 would be a nice upgrade from that Yamaha......I gather. The svs website states the PB1000 width @ 15" but incorporates a 10" driver. Hsu VTF 2.4 is about the same width but uses a larger 12" driver as does the Rythmik LV12R but its 16" wide. Both would likely better the smaller Svs....the downside to the latter two though...with shipping they could exceed your pals budget but only marginally....for <$600.00 those 3 sub are at the top of the list IMO.
3db
3db
Rythmik currently has a sale on the LV12R of 549.00 including shipping. Checked it out.
shadyJ
Speaker of the House
Staff member
Hsu has a sale on the VTF2 at the monent as well, $566 shipped.
3db
3db
Hi guys,
SVS PB-1000
Any suggestions?
thank you
Did you tell your friend about the sale that Rythmik has going on?
bizmord
bizmord
So, ultimately he is probably going with this one ...
Yamaha soavo 900sw subwoofer
thoughts?
anamorphic96
anamorphic96
thoughts?
That Yamaha while ok will not go low enough the way an SVS or HSU will. Sorry I have not heard a Rythmik sub yet.
rojo
rojo
Tell your friend he should lean towards buying a sub from a sub company, not just an audio company who happens to make subs to complete the set of their other speakers*. Or if he doesn't mind a diy project, the ultimax or the HO kit from Parts Express would best anything pre-finished.
The more you know.
* Note: Hsu and SVS sell full range speakers as well, but their roots are in subwoofers.
Sent from my LG-VS980 using Forum Fiend v1.3.1.
afterlife2
afterlife2
What is his room size?
PB1000 is $476 outlet sale.
bizmord
bizmord
just curious ... other than judging this system based on specs ... has anyone ever heard it? the full package ... the speakers + sub
thank you
bizmord
bizmord
Here is an argument .... you guys tell me what you think ....
He said, his Yamaha sub is using a paper woofer and thus even a 10inch will sound bigger and bolder than a 12" Rythmik F12 because it doesn't use paper material for woofer.
thoughts?
slipperybidness
slipperybidness
thoughts?
I think that's some faulty reasoning right there.
The material doesn't really matter, it's the overall design and the measured specs that count!
Paper cones have advantages! Lighter moving mass is easier to control (I think the technical term is "less overhang"). The disadvantage is that paper is not as rigid as other materials. Thus, modern paper cones are typically some composite material.
You must have a listen before passing some sweeping general judgment like that!
3db
3db
Let me put it this way; I've never experienced pitch changes in movie soundtracks before until I got the Rythmik. Even for a ported sub with a paper cone driver, it will put many non paper cone subs to shame.
