That was a very interesting article. I think most people are surprised to find out how little low bass content there actually is in most music (almost nothing below 40 Hz, except for pipe organ pedal notes, and maybe bass drum and tympani), and how the fundamental tones of even high-pitched instruments are not very high in frequency.
One other comment about guitars - one reason for solid-body electric guitars sounding so different than amplified acoustic guitars (or acoustic guitar played through a microphone) is the lack of high-frequency content in the signal chain for an electric. I'm not sure about the exact frequency response of electric guitar pick-ups, but it is pretty limited. Also, guitar amps usually use 12" woofers as their only speakers. (Sometimes a bit smaller, but the typical arrangement is for 1-4 12" speakers.) So, the high frequency response is limited by the speaker's frequency response, if nothing else.
To capture the higher-frequency transients that make an acoustic guitar sound the way it does (the transients of the initial string impact, for example), you either need to play it through a microphone, or else use special pick-ups that have a wider frequency response. In addition, guitar amps that are specifically designed for acoustic guitars usually have tweeters as well as woofers, to capture the high frequency content better.
BTW - in the telecom world, the basic assumption for the required frequency response needed for adequate voice transmission is 200-3,400 Hz. That's why the sampling rate for digitizing telephone voice circuits was set at 8 KHz (a little more than twice the desired upper frequency limit). Contrast this to 44 KHz for "red book" CDs, to allow frequency response up to 20 kHz..
Most people are familiar with how their own voice sounds a lot different when listening to a recording, compared to how it sounds to yourself. This of course is due to the fact that you are hearing your own voice through not just your ears, but also the sound waves propogating through the bones of your skull, through nasal passages, etc. If your ears are ever plugged up, you hear relatively more through the "low-pass" filter represented by your skull and nasal passages. If any of you have ever had a bad case of tinnitus (ringing in the ears), then you know how it also changes the sound of your own voice. I THINK this is another case of severely rolled-off high-frequency response. I had tinnitus once for several weeks, after going to a Who concert. (Ironic, considering Pete Townsend's hearing problems.) It sounded like my own voice was lisping, but in reality the high-frequency content of my voice was being rolled off. It didn't get any better for 3 or 4 weeks, and then I woke up one morning and the ringing was gone. I've always wondered if my ears actually got better, or if my brain just figured out how to compensate!
