Frequency Response Question
F
Fife
I'm looking to purchase a Boston Acoustics CRC7 center channel speaker. I have owned CR8 fronts for many years (I know they have a low sensitivity). The frequency response for the center channel speaker goes as low as 80hz +/- 3db. That number must represent a decibel droppoff per number of hz closer to its lowest limit. Does anyone know where the droppoff curve begins? I ask because I have the option of crossing them over at 80 or 100hz. I'm thinking 100 is better. If I did 80 would their be a sonic hole? I have my fronts crossed over at 80hz. I can't seem to get hold of a frequency response graph.
Thanks
L
Leprkon
Thanks
Hmm.. first of all.. are you talking a HT-type application or a DVD-A / SACD application ? HT is much more forgiving.
The drop-off is not really "per-decibel". It's actually a total loss of 3dB from the signal strength at the peak frequency when measured at 80. When you drop from 80 to 79, you won't lose 3 more dB. It might be a total of 3.1 dB, but it won't be 3 + 3 for a total of 6.
For an HT application, one thing that might help you decide would be the size of the drivers. If the mains have a larger driver than the center, they will probably (no guarentee here) go lower than 80 Hz. If they are the same size as the center, then a crossover of 100 would probably be a better bet.
For audio DVD or SACD, I'd set the crossover to 100 as well.
F
Fife
Thanks for the reply. My receiver (HK 235) allows me to cross over each speaker "pair" at different points. My fronts have a response down to 60 hz. I have them crossed over at 80 hz. I will mainly be using home theatre and CD music. I will probably not use the pure direct mode because I feel I need the subwoofer. My fronts just aren't large enough. There is a stereo mode that enables the subwoofer. I don't forsee any SACD or DVD-A use in the near future.
Thanks
N
nm2285
3db is not a great audible difference. there would be no gap if you chose 80. i would usually cross them over lower for music, higher for movies (because the smaller drivers usually produce more musical bass as long as it is within their limits)
crashguy
crashguy
If they are rated to 80 Hz +/- 3 dB, that means that at 80 Hz, they are 3 dB down from the average of the rest of the response. It may be better described as a "lower frequency response limit" which may make it make more sense.
