Just like they told you, both here and at AR, without a variance (+/- db) range, the specs are worthless. While the first speaker "may" accept signals at 20 hz and attempt to play them back, it could well be at a level so far down from the rest of the range that it will be inaudible.
Note on the second speaker that two ranges are given, the first within 3 db and the second, where the range gives a variance of +3/-9 db. This means that as you approach the extents of the speakers range, it's level drops, sometimes significantly.
I'd be somewhat hesitant to take the first speakers specs and assume that, based simply on the overall range stated, it's "better" than the second ones. At least the second speaker tells you where it falls off. The first doesn't. What does it have to hide?
