duder1982
Title says it all, I'm looking for a rackmount kit for a Marantz AV7704. Pm if you have one.
duder1982
Have a look at these Penn-Elcom products. I'm using one with my Denon AVR:
Does your Denon have side vents and if so, does it seem to run hot? I have a 4u rack shelf similar to the one you recommended minus the bezel and maybe a little less side ventilation, but was concerned of over heating.
There is 1 RMK8003AV on Ebay now, just need to confirm it works with my model.
My other thought was to use a 2U rack shelf, but figured if I was going to spend $40 on that, I could spend $80 on an actual rack kit.
Look for 'vented rack shelf'.
Or, you could use this-
duder1982
Thanks for all the recommendations, I ended up scoring a rack mount kit off of the bay. Should have it next week.
