Fostex TE-07 Stereo Earphones Overview
HTKamikazee
Audioholics Sheriff
Earlier this week, I made an overview on the Fostex TH500RP Premium Headphones which you see here: http://forums.audioholics.com/forums/threads/fostex-th500rp-premium-rp-stereo-headphones-overview.94366. Today's overview is about their TE-07 Earphones - which I found quite interesting.
The TE-07 have some interesting features besides construction characteristics, so make sure you read the features list and specifications below for details.
This what the company had to say about this model:
"The TE-07 is the first IEM from Fostex that adopts balanced armature type driver, being thoroughly tuned by Fostex headphone engineers, delivering extremely natural and transparent audio performance.The TE-07 also features newly designed 6N cable with the same detachable connector compatible with the TE-05, which will be separately sold as ET-H1.2N6." Check out the following features and specs and let us know if you have had any experience with any Fostex product.
FEATURES:
  • Detachable connector for easy replacement of the cable when damaged.
  • The detachable 6N cable model ET-H1.2N6 also fits the TE-05 for upgrade its standard cable.
  • The Right unit of the connector has a small projection in red for easy identification.
  • Single balanced-armature type driver for extremely natural and transparent sound.
  • Machined aluminum housing for brilliant sound characteristics.
  • Handy leather case with embossed Fostex logo included.
  • 4 size ear tips (XS, S, M, L) for perfect fit to ears.
  • Comes in a beautifully designed package.
  • The connector part is “MMCX” type, but Fostex does not guarantee any compatibility with cables from third parties.
SPECIFICATIONS:
  • Type: Balanced armature
  • Frequency Response: 20Hz – 20kHz
  • Impedance: 33 Ohm
  • Sensitivity: 95 (at 1kHz, 1mW)
  • Maximum Input: 5mW
  • Plug: 3.5mm, 3P mini plug
  • Cable Length: 1.2m
  • Accessories: Spare ear tips (XS, S, M, L) and Leather Carrying Case
Price: $249.99
Click on the following thumbnails to zoom in.
TE-07_connect_3000x2026.jpg te-07_connect_image_3000x2026.jpg TE07-in-Pouch-0032.jpg
MR G
I have a pair of these, and when paired with my Fostex HP-P1 and a classic Ipod the music is sweet!
