The ASW1000 active subwoofer adds a new depth to B&W's quest for perfect sound reproduction. It has been designed specifically to deliver a punchy and precise bass response so vital to a Home Cinema surround sound. This has been achieved only by use of the very highest quality components, together with technical innovations for which B&W is famous. These include B&W's world beating Flow Port system and a new ultra low frequency 12 inch drive unit. To ensure fewer demands are imposed on your main amplifier, the ASW1000 also has its own audiophile grade 120 watt amplifier. Added to your home cinema system, underpinning the higher frequencies with a fast and articulate bass response, the ASW1000 will truly enhance your listening pleasure.
* Frequency Response:±3dB 25Hz - 40/140Hz adjustable response
* Low-Pass filter:Active 4th-order, variable cutoff frequency 40-140Hz
* High-pass filter (Line level):active 3rd-order at 80 Hz
* High-pass filter (Speaker level)
assive 1st-order at 80Hz into 8 ohm resistor (response using speaker level connections dependent on satellite impedance)
* Sensitivity:90dB spl (2.83V 1m)
* Power output:120W continuous
* Signal/Noise:90dB
* Input Impedance:22kohms
* Functions:Input Level Phase 0/180 -Low-pass filter frequency -1x 300mm (12in) dia long-throw with magnetic shielding
* Dimensions:Height: 460mm (18.1in) /Width: 540mm (21.3in) /Depth: 500mm (19.7in)
* New Weight:30kg / 66lb
* Cabinet:Black Ash Vinyl
* Grille:Black Cloth
Paid $1150, selling for $700 CDN
Includes Original Box and Manual
http://www.bwspeakers.com/downloadFile/speakerModel/ACF180F.pdf
