If you already have or just ordered your Dimension Soundbar from Focal, let me tell you that you can give its performance a good performance boost with the Dimension Sub.
This sub was designed to fit behind the Dimension soundbar and provide deeper bass down to 30Hz (according to Focal). Just use the existing sixth amplified channel on the soundbar and you'll be ready to go in a matter of minutes. Not only this sub will give lower frequencies, bit it will also increase the power handling of your system reaching a maximum SPL of nearly 105dB. Not bad for a soundbar system!
According to Focal, you don’t need to worry about vibrations affecting your screen because the Dimension Sub features 2 elliptical woofers working in opposite (« push push » system).
KEY FEATURES:
- Zero Vibration Concept.
- Adapted to screens measuring 50″ and more.
- Frequency response: 30Hz – 110Hz.
- True sound plate for your screen.
SPECIFICATIONS:
Price: $399.00
Are you a Focal fan willing to try this one? Let me know what you think!
