FM Modulation and signal quality
jcPanny
jcPanny
I currently have 2 XM radios that are used in the car and at home. Out of convenience I am using the FM modulation function to send the signal from the XM radio to my Yamaha receiver.
Since XM is digital and closer to CD audio quality, am I degrading the signal quality by using the FM modulation function? Could I expect a better quality signal using the headpone jack to RCA connection to the receiver?
I think the same quesion applies to Ipods and other audio sources.
Hi Ho
Hi Ho
FM has limited frequency range. FM is not CD quality. You would get better quality with a direct connection.
I use an FM transmitter in my car with my MP3 player because I saved $20 when I bought the head unit and got the one with no auxilary input. :mad:
It does work well though and the sound quality is decent though I would definetly use the direct inputs if I had the option.
I do have a min-jack to RCA cable hooked up to my receiver and I just plug the player in and it sounds great. With WMA/MP3's at 320k and lossless songs the sound quality is equal to the original CD.
