Johnny Canuck said:
Polk LSi15's. Surprised 20to20k didn't recommend them
I have the RTI12's and wished I bought the LSi15's. They seriously kick the paradigm studio 100's. No contest.
Funny you say that. Your RTi12's have a much better frequency response, much better bass (3-7" woofers as opposed to 1-8"), 6 drivers as opposed to 4, handle amps rated at 50-500 watts as opposed to 20-250 watts, weigh 88 lbs ea opposed to 66 lbs, and are rated at 8 ohms as opposed to 4 ohms. JMO, but I felt the RTi series sounded much more realistic than the LSi's. A lot of people got the impression Polk was trying to save money with the LSi series. I think they're both award winning speakers, but to knock your own set that should blow the socks off the LSi15 is mad. Have you had both sets in your house to demo? I did in Tweeter several times. Here's a review pulled from the Polk website on the RTi12's:
"REVIEW:
After listening to jm lab,totem,monitor audio,paradigm,mirage and few others need not mentioning I managed to come to the conclusion that there was truly nothing out their that offered everything thr RTI12 had to offer for the price. I do however have to say that the consumer with a home theatre reciever will not get the range or authority out of these that they posess with the right amplification.
Bottom line is that if you truly want to here these speakers run a good power supply as I hooked them up to a Denon 3802 and I was very dissapointed, however after conecting them to a Bryston 4B they came to life with an unbelievable level of punch and detail that came across as smooth as butter with vocals to die for!!!"
Originally Posted by 20to20K
Those Paradigms are as about as good a $2000 speaker ($2200 list) as I've heard. If you want to save a little you may want to check out the Quad 2.2L as well($1600). Harder to find a dealer though but they are outstanding and take up less space if real estate is an issue...
A friend of mine has the Paradigm 7.1 setup with an older Denon 2803 and they sound wonderful. They do sound different than Polks though, and they are more efficient (isn't everything).
