Hi Ho said:
I cannot look at a CRT PC monitor set lower than 85hz without getting a serious headache. The same goes for plasma TV's.
However, I can watch my 27in CRT TV for hours and not experience a single flicker or headache. CRT TV's run at 60hz. If I looked at a PC monitor running at 60hz I would be in agony from the horrible flicker. Why is this?
I not a physician, but I can propose several answers, and suggest some advice.
Think spatial relationship relative to the refresh rate.
You are physically closer to the PC monitor. You are able to distinguish details on that screen which you would not be able to distinguish on your CRT TV. The low refresh rate on the monitor is actually visible (consciously or subconsciously) to your eye/brain.
(in a way, the plasma monitor has the same problem ... great details)
Technically your eye is tracking the refresh line as it passes across the screen. This tracking movement could be causing eye fatigue and your headaches.
Why you are sitting that close to the PC monitor could be an issue for your eye doctor. You may need an update prescription, or your first pair of eye glasses.
Then there are serious problems.
Way back in high school I dated a girl way that could not sit close to a TV or the screen at the movie theatre. The flicker would cause a specific type of seizure.
There are different types of seizures. Some types of migraine headaches are considered a seizure, or a precursor to a seizure. And light, noise and other stimuli can trigger these seizures.
It is possible that when you are close to a monitor or display, or have a monitor-display that has a relatively low refresh rate (relative to your distance) you are trigger the neurological response that is generating the headaches.
Since these headaches could be a sign of a serious problem, I would not ignore the problem if it continues.
But first, visit the eye doc. Most likely a new pair of glasses will solve your problem.
