After reading a bit about how speakers ideally should be neutral, I ask the question, have not speakers in the past and present met this goal? If so, it should be quite easy to just size up the power requirements for the speakers and match it to a power supply to provide the music. Is there no such reference? Say I had a vintage Marantz 2245 receiver, 45 watts a side, could there not just be a list of neutral speakers that "fit" this power supply, then go and buy those speakers and game over? I remember using a graphic equalizer, an lp with different frequencies and a db meter. Match the frequencies produced by the speaker via the correct equalizer slide, adjust the slide to attain the correct db, tada! tuned speakers. Is this the same thing? Cheers, Rick.
