N nm2285 Senior Audioholic Mar 2, 2004 712 0 18 Mar 11, 2004 #1 <font color='#000000'>this is my first (possible) venture into separates. what does an integrated amplifier do? what are advantages to using one? thanks!</font>
A. Vivaldi Audioholic Jan 13, 2004 190 0 0 Mar 12, 2004 #2 <table border="0" align="center" width="95%" cellpadding="0" cellspacing="0"><tr><td> nm2285 : <font color='#000000'>this is my first (possible) venture into separates. what does an integrated amplifier do? what are advantages to using one? thanks!</font> Click to expand... <font color='#000000'>A integrated amp is like a receiver without the tuner capablity (radio). By not having a tuner housed in the same chassis, a manufacturer can spend/fit more putting bigger transformers and better wiring and things like that. Integrateds are a great way to go if you don't have a lot to spend, and you can still get a separate tuner later. Some even think they're better than true separates because there's less in the signal path, no cables between units and stuff like that. However, separates offer more flexibility in that you can use different brands, multiple amps and upgrade more easily. I would only purchase separates if I had lots to spend on something decent.</font>
Z zumbo Audioholic Spartan Jan 28, 2004 6,517 0 113 Mar 12, 2004 #3 <font color='#000000'>2-Channel Integrated amps do not have the .1 sub output. I had mentioned this option to you before you said you needed 2-channel and a sub! I have a new post in your other thread! </font> Last edited by a moderator: Oct 23, 2014
A. Vivaldi Audioholic Jan 13, 2004 190 0 0 Mar 12, 2004 #4 <table border="0" align="center" width="95%" cellpadding="0" cellspacing="0"><tr><td> zumbo : <font color='#000000'>2-Channel Integrated amps do not have the .1 sub output. I had mentioned this option to you before you said you needed 2-channel and a sub! I have a new post in your other thread! </font> Click to expand... <font color='#000000'>You can hook up a powered sub to any integrated amp that has pre-out sockets on the back.</font> Last edited by a moderator: Oct 23, 2014
G Guest Guest Mar 12, 2004 #5 <font color='#000000'>Several subs do not require a sub out.See the Musical subs string. Vandersteen, Revel and certainly some others.</font>
