First time sub connection question
  • Thread starter Thread starter micalma
micalma
2
0
0
I've had my home theatre set up incorrectly for a while now and would like to set it up the correct way.
What type of cable do I need to connect my sub to my receiver? Should there only be one connection betweent the 2?
Lastly, how much should I expect to spend and what are some recommendations for brands?
I live in a small apartment if that makes a difference.
Thanks in advance for your help.
What receiver and what sub are you running?
Yes. A single connection with a standard audio interconnect cable with RCA plugs. Buy whichever one is long enough to connect the two. Brand is immaterial.
