First time buying an amp, need some serious help
G
gchanjam
I've never had any real serious home theater gear but I just picked up a pair of Polk LSi15's and I am also probably going to be buying another pair of Def Tech's. However, my Onkyo 705 is not really cutting it with the Polks so I am in need of a good amp to run them on. The problem is that I know very little about amps and what makes a good one from a bad one.
Most of the amps that I've looked into are either far too expensive or just not good enough. So, I am looking for a nice midrange stereo amp and I don't quite know where to start looking. Any help would be appreciated.
Haoleb
Haoleb
Start with a budget. Decide how loud you would like to listen, And go from there. by mid-range im guessing about the $6-700 range.
Personally in that range I would be looking at a used Odyssey Stratos, NAD C272, maybe a Parasound Halo A23.
cfrizz
Look for a used 200wpc amp on Audiogon. Rotel, Parasound, Outlaw, Sunfire, Adcom, B & K will all get the job done.
G
gchanjam
That's the thing. I don't actually know what qualifies as mid-range as far as amps go. I figured around $500-$600 but it seems that might be low-balling it a bit. I don't really need it to go all that loud but I know that my Onkyo 705 isn't letting me use my LSi's to anywhere near their full potential.
Jacksmyname
If you're just looking for a two channel power amp to use with your current receiver, also take a look at the Emotiva line. Emotiva, along with Outlaw, gets rave reviews.
Their RPA-1, a two channel 200 watt/channel amp, is supposed to be replaced with a new model soon.
mazersteven
mazersteven
Loud is only a small part of it. The speakers love power, and they seem to open up, and just sound better. Adding an external amp to the LSi's will reveal detail, and clarity in music, and movies. :D
Since you don't need it to go all that loud, I would say the NAD C272 suggested to you before can do the job.
http://207.228.230.231/info/C272_data.pdf
Only 150 WPC into 8 ohms or 4 ohms but the it has huge headroom/dynamic power. You can probably get one new for under $800.
highfihoney
highfihoney
Ditto,proven build quality,proven long term performance,good resale value,high headroom.
You cant ask for more in your budget.
Haoleb
Haoleb
Of course you could get the used stratos for the around the same price as a 272, and its in an entirely different class in every way. ;)
O
ozz316
I'm new to the whole high end home audio stuff, but I have seen that Carvin amps are very reliable and provide cheap power in the music industry. I personally do not own one, but plan to put together a amp/preamp bass guitar stack with one. The power seems clean from their specs and from what I have heard are reliable down to 2 ohms per channel. Just a suggestion, I don't know how wide spread these are used in home theater, but look like they might do the trick. http://www.carvinguitars.com/products/group.php?cid=15
bandphan
bandphan
2ohm speaker in ht?:confused:? What about processing?Also 1/4 inputs and balanced only leave you with few choices for pre(price wise) oh never mind just keep reading up....im not very versed in bass stacks and i dont use one in my ht,
good luck
bandphan
bandphan
and as for power in the music industry,that would be live music, correct? in a engineering aspect isnt it about accuracy instead?
O
ozz316
good luck
OUCHHH!!! I guess next time I try to throw something a little different out there I'll just keep my mouth shut:eek:. As far as the 2 ohms is concerned, I'll remember that statement next time I read a post on here where someone is upset because their amp is shutting down trying to drive their 4 ohm speakers that are actually 3.8 ohms.
As far as connectivity for preamp http://www.topdjgear.com/hohedu1to1ca.html this should take care of your concern for a whole $10.
Once again sorry for voicing my opinion where it is not wanted.
MUDSHARK
MUDSHARK
Consider going used to stretch your budget. Amps are the best thing to buy used beacause the good ones last for eons. The Outlaws have a good reputation BTW.
bandphan
bandphan
its all good, just was quick with the keys.. pointing out the obvious only, not flaming... note the good luck comment...:)
sorry for highjacking the thread guys.
