Shug
Hi everyone! I have been reading the material on Audioholics for a while and want to clear up some terminology that I am uncertain of, so with your kind indulgence...
What is meant by the term "Reference Speaker"; or Reference anything for that matter? From my humble perspective of just reading it in context, it sounds like a subjective term used by Audiophiles as a common frame of reference to compare similar equipment against. Is there a certain quantifiable set of standards by which some piece of equipment meets a reference standard? If so is there any suggested reading material that you would recommend so that I can cure my ignorance? Part of my confusion is when I see manufacturers use "Reference" as a marketing term. Can someone tell me what is implied when this term is used?
Thanks in advance.
Jeff
Thanks in advance.
Jeff
