First time HT noobie looking for some input on speaker connections and constructive criticism. HT set up in living room. Room size is 20x16x8.
Trying to keep budget under control cause i don't know if residence will change in near future. I'm making final selection on 46" LCD (most likely samsung) and I want to insulate and sheet rock last wall without forgetting anything!
-A/V receiver Onkyo Tx-sr 705
-Speakers Boston Horizon MSC-130 5.1
-Gaming PS3
-Cable Comcast HD
- A/V Rack Mid Atlantic in-wall pull out/rotating.
Here are some pic's of rough in, pass through plate, and speaker rear mount and terminals.
Questions:
1. I'm using pass through plates behind front 3 speakers and subwoofer to minimize connections and to mount speakers directly to the wall , terminals won't accept banana plugs but receiver will, in wall wiring is 14 AWG, should I terminate to speaker terminals with a quality ring / spade connector , receiver with banana plugs(solder or solderless?) or use bare wire for all?
2. I need to stud TV wall above A/V rack and install 3 single gang boxes along with TV mount (1) 120v (1)Center Speaker below TV (1) HDMI with a flex conduit run to box behind a/v rack, can i purchase the TV mount before final selection just on TV size or should i buy them together and finish?
3. Surge Protection and power conditioner, any suggestions on unit that will give me protection for all 120v connections, cable, and receiver antenna?
Any input is appreciated. Thanks.
