Hi Kyle,
First off, congrats on being able to plan&build your home theatre. If I may be so humble with some advice for you, please make sure you concentrate on the " room " first. If this is your dream home, this is an absolute must. I've had my home theatre /stereo room for 20+years now, & I couldn't be happier with it! (Equip. upgrades aside. lol.) Make sure you run at least 2-3 dedicated power lines, with a min. 20 amp. rating, to the spots that you have dedicated your equipment to. Also, have at least hospital grade outlets to all the recepticles in your room. Then make the room a " floating " room. That is, a room within a room with rubber grommets on the framework, and 5/8 drywall with a brand like Roxul insulation between. If this room is in the basement, then put the largest grade underpading along with a heavy duty carpeting. ( I've had my carpet for over 20 year's now.) Anyway, next up plan exactly where you want your speakers to be, (always plan for further speakers, trust me on that!) You want to run a good to better quality speaker wire of at least 14 gauge. If your budget permits, go with 12 gauge. A lot of people will disagree with me on this one, but I say, do it the best way you can afford to, if this is truly your dream home. When you run your wire of choice behind the walls, do not let any of the wires cross one another at any time. You don't want to find out you have a ground problem after the drywall is up
If you have to cross wire paths, make a small wooden bridge if you will, one over, one under. Remember, zero wiring problems ever! Straight paths, keep wires apart at least 1-1/2 " apart. Paint your ceiling with dark, sound deadening paint. Min 2 coats. If you want to have your main speakers behind a perforated screen, ( that's what I have.) Paint the rear wall the same way, and make sure the carpet extends inside. Run at least 2 outlets behind the " LARGEST SCREEN POSSIBLE. have cable outlets for min 6 speakers ( future expansion). Now plan out what type of general lighting scheme and run SEPARATE wiring right from your main panel, to the lighting inside the room.
Forgot to mention make sure you put a wooden panel of 1/2- 3/4" in the ceiling spot for that kick ass projector, as well as a dedicated ceiling outlet . I also have a Furman power conditioner (ac215) for the projector. Next up, put in an oversized insulated door of choice if possible, for equip. & furniture moving with less headaches. Make yourself an insulated 3" platform for your seating. (You just might go the extra & install a passive radiator or expensive dbox seating). Last up, get yourself a really good equipment rack/stand/closet, etc.
This will cost you a fair bit, but in the long run, it will sure pay for itself over & over again. I hope other readers will comment on many more ways in which will help you reach your goals.thank you & good luck! I hope I have been able to help in any way. Thank you,. Brian
