Finished the mod on my ent. center.
DonBattles
DonBattles
Made new risers for the box that the TV sits on, needed to make room for the MA center. Have a look at the before and after, made some legs from cork as well to get the speaker at a better listening angle.
That looks great. What are the legs made from? Paint it the same color as the wood finish to blend in?
DonBattles
DonBattles
Made from simple MDF, I painted it with black textured paint which is the same finish that's on the sliding shelf the TV actually sits on. I went with the black because the speaker is black and with the grille in place it all just sort of blends. I might even build a grille that covers the entire area hiding the speaker all together, but I'll try it this way for a bit.
