First i will tell u about my set up
- 19' x 16' living room,
- TH-42PHD8UK-42" Widescreen Professional HD Plasma Display
- Yamaha Av reciever RX-Z1
- Paradigm SA 35 in-wall front (L/R) speaker
- Paradigm SA 15 in wall rear (L/R) speaker
- Paradigm PS-1200 - 12" sub woofer
question:
I'm been looking until my eye get blurred from the comp. screen for a front Centre speaker that need to be a in-wall like my paradigms, having a hard time finding one that is equal or better then my main front speakers (specs of SA 35 in-wall below). Paradigm for some reason do not sell in wall centres, would anyone no of a high end one that is equal to my SA 35's? I see alot of centre out there but hard to find a high end in wall one..if someone can help me out that would be great..
I'm waiting on my plasma,its on order, i'm itching to hook it all up, but the only thing left to buy is high end centre..don't want any hanging ones, just in wall flush ones..willing to pay up to 600 ca dollars.
Paradigm SA 35 series front L/R speaker SPECS
design
3 drivers,2-1/2-way
in wall/in ceiling with die cast/mounting brackets
Cross over
3rd-order electro-acoustic at 2 KHz
2nd-order electro-acoustic at 500 Hz
(lower base driver)
hight-frequency driver
25-mm(1 in.) PAL pure aluminum dome, die-cast headsink chassie, ferro-fluid damp/cooled
Bass/mid range
210-mm (8in.)
MLP mica-polmer cone, die-cast heatsink chassie, 38mm (1-1/2 in.) voice coil
low-frenquency extension
34 Hz (Din)
Frenquency response
on-axis
+,- dB from 46Hz-22KHz
30 degree off axis
+,- dB 46Mz-20KHz
sesitivity-room/anechoic
95dB/91dB
suitable amlifier power range
15-250 watts
maximum input power
180 watts
Impedance
compatible with 8 ohms
