Finally matching subs
W
waxey
just got my new YST-SW315 to replace YST-SW105 I was runnig with the SW-315 I aready had. They sound great togeather.Room is only 17X13X8 more than enough bass for that sise area.They also blend in well with fronts studio 100 v5s.I know there not svs,hue, velodyne etc;but they do sound pretty good especially for the price.
Receiver Yamaha rx-v1800
T.V.Panasonic TC-P50V10
B.D player Panasonic DMP- BD60
C.D. changer Yamaha CDC-697
Fronts Paradigm Studio 100 V5
Surounds Paradigm Studio 40 V4
Sub Yamaha YST-SW315 X2
Rears Polk M3II
VCR - Cable Scientific Alanta Explorer 8300
:D Center Def. Tec.CLR 2002
dalessandro12
Out of curiosity, are you satisfied with the sound of your center with the unmatched L/R fronts?
I was originally going to order an unmatched center but since my surrounds and center are timbre matched, I figured I should just go ahead and order the fronts so my whole system is matched. I am happy with the system that is in place now but haven't set it all up with the receiver yet, so I've mostly been just plugging them in temporarily to play with them.
W
waxey
the center chanell matches pretty good with the paradigms for most dvd & bd movies all though sometimes a little week for some. when that happens I turn speaker level up for the center a bit. As far tonel quality its not bad.
