3db
3db
bass covers 20Hz to ????
Mid bass covers ???? to ????
Lower Mid ???? to ????
Mid ???? to ????
Upper Mid ???? to ????
Treble ????? to 20 KZz
Davemcc
Davemcc
Good question. These are terms thrown about pretty loosely without any real definition to their use. Since there are no takers, I'll try first and others can tell me why I'm wrong. I'm very interested the answers that follow.
bass covers 20Hz to 80Hz
Mid bass covers 80Hz to 200Hz
Lower Mid 200Hz to 500Hz
Mid 500Hz to 2KHz
Upper Mid 2KHz to 5KHz
Treble 5KHz to 20 KHz
STRONGBADF1
STRONGBADF1
Great question.
I don't have an answer...Yet.:)
I have to think on it.
SBF1
STRONGBADF1
STRONGBADF1
Mid 500Hz to 2KHz
I'll do it this way and as above "tell me why I'm wrong":)
bass covers 20Hz to 63Hz
Mid bass covers 63Hz to 250Hz
Lower Mid 250Hz to 630Hz
Mid 630kHz to 1.4KHz
Upper Mid 1.4KHz to 4KHz
Treble 4KHz to 20KHz
Close to Davemcc's. I looked at a graphic EQ and divided it up. Maybe not the correct solution but it's a starting point.:)
SBF1
jostenmeat
Im curious about educated responses here as well. Some little factoids:
-highest string of a violin, unfingered, is 660hz. But it's uppermost range is a bit under 3.5khz (IMO, very treble!) and this does NOT include extended techniques such as artificial harmonics
-lowest unfingered note on a guitar is just a shade over 80hz. A 6-string electric guitar with 24 frets goes up to 1320hz. Again, not including extended techniques, such as bends, whammy bars, bending neck, art harmonics, electronic devices.
-Bass vocalists sing below 80hz. However, these same bass vocalists will sing up to 330hz.
-soprano will sing between (roughly) 250hz to 1.2khz.
-lowest note on a double bass is not far from 3 octaves below middle C. However, its uppermost range gets to above middle C!
The above are the "normal" ranges. Various individuals can and will go beyond limits, whether below or above. Most of my math above is using 440hz as concert A, and applying "perfect intervals" when my math-challenged brain is at work. Untempered, if you will.
Hm, well looking at the attached graph, I guess my efforts are wasted. lol.
It seems the most difficult classifications are from the mids-on-up. I guess I would consider everything above 800-1000hz as treble already. (It's already an octave above Concert A, or 440 hz). It's difficult to accomodate both the audiophile's and musician's perspective, at least it seems to me. For instance, I personally think the 24th fret is pretty treble! But with the attempted tries above, it's only "Mid"! :eek: :p
This is a good idea though to shed light on this stuff....
STRONGBADF1
STRONGBADF1
My bet is that most of us couldn't guess notes frequency in a blind test.
SBF1
