It's quite difficult to find approximate properties for fibreglass or, as I suspect is actually meant here, glass reinforced plastic (GRP) as opposed to the loose fibreglass used for insulation. Are you sure that the density of fibreglass is greater than that of MDF?
Light aircraft are made from GRP and material
strength aside, my gut's telling me that it'd be lighter than a similar aircraft made of MDF.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
D)
What little I could find out about GRP revealed that its stiffness is approximately 3 to 8 times greater than that of MDF. If correct, and conservatively adopting the factor 3, a panel of any given thickness made from GRP could be seven tenths the thickness of an MDF panel yet deflect equally under uniform load. Just thought you'd like to know.
