Bad case of upgradeitis is causing me to explore my options.
Just grabbed a pair of AV123 minis, so..
iQ9 Dark Apple: $799 (excellent write up in numerous mags at $1200)
iQ6 Dark Apple $299
iQ3 Black $349
All about 1 yr old excellent condition/all original packing material and iQ9s will be double boxed.
Main Features iQ9
Magnetic Shielding Yes
General Features
Color Dark Apple
Crossover Frequency 250Hz - 2.8kHz
Frequency Response 38Hz-40kHz
Impedance 8.5 ohms
Sensitivity 91dB
Speaker Type Floor Standing, 3-Way
Inputs / Outputs
Speaker Terminals 5 Way Binding Post
Dimensions
Weight (Pounds) 36.6
Depth (Inches) 12.9
Height (Inches) 37
Width (Inches) 8.7
Detailed Specifications:
Design: Three-way bass reflex
Drive units: 2 x 165mm (61⁄2") LF 165mm (61⁄2") Uni-Q 19mm (3⁄4") aluminium dome HF
Frequency response: 38Hz - 40kHz
Crossover frequency: 250Hz - 2.8kHz
Amplifier requirements: 15 - 200W
Sensitivity (2.83V/1m): 91dB
Maximum output: 113dB
Nominal impedance: 8½ (min 3.2½)
Magnetic shielding: Yes
Weight: 16.6kg (36.6lbs)
Dimensions :942 x 220 x 327 mm H xW x D 37 x 8.7 x 12.9 in.
iQ6c specs
Drive units: 2 x 130mm (51⁄4") LF 130mm (51⁄4") Uni-Q 19mm (3⁄4") aluminium dome HF
Frequency response: 65Hz - 40kHz
Crossover frequency: 280Hz - 2.8kHz
Amplifier requirements: 15 - 150W
Sensitivity (2.83V/1m): 90dB
Maximum output: 111dB
Weight: 8.9kg (19.6lbs)
Dimensions: 165 x 512 x 255 mm H xW x D 6.5 x 20.1 x 10 in
Pictures to follow~~~
Rgds,
Paul
