Just checking to see if there will be any interest.
Onix x-sub:
is in very good condition, with the only blemish being the black paint on one of the feet flaked off in 2-3 spots.
It's the white shadow maple finish. and made in China.
I am the 2nd owner.
Has original box and packing. with power cord.
- Connections: Speaker-level stereo in/out, line-level stereo in, LFE mono in
- Enclosure Type: Vented
- Woofer (size in inches, type): 8, treated-paper composite cone
- Power Rating (watts): 150, RMS
- Crossover Bypass: Yes (via LFE input)
- Finish: White Shadow Maple
- Dimensions (H x W x D, inches): 17.75 x 9 x 12.88
- Weight (pounds): 44
The Onkyo M-282 power amp:
hardly used (less than 5 hrs, I'd say). in mint condition. has line in AND out jacks; same components as the integra 2ch power amp with different model number.
Has original box and most of packing. comes with power cord.
product info:
http://onkyousa.com/model.cfm?m=M-282&class=Amplifier&p=i
- Power Output 2 x 125 watts/channel into 6 ohm
- Dynamic Power** -
- 2 ohms -
- 6 ohms -
- 8 ohms 2 x 140 W at 8 ohms
- THD 0.08 % at rated power
- IM Distortion Rated Power 0.08 % at rated power
- Damping Factor 100 at 8 ohms
- Frequency Response 10 Hz to 100 kHz: ±1 dB
- Signal-to-Noise Ratio 110 dB (IHF A, 0.5 V input)
- Dimensions (W x H x D) -
- Inches 17-1/8" x 5-11/16" x 12-7/16"
- Weight 18.7 lbs
Actual pics of both can be posted on request.
I am still researching on suitable prices, so if you are interested and have any offers, PM me or post here.
I will post asking prices soon;
wanted to check if there will be any interest first.
