We're finishing our basement and the ideal spot for our AV set-up is tucked around the corner. Certainly not optimized for ideal acoustics, but it gives us good flexibility with a newborn on the way and our life about to change rapidly.
![r/hometheater - Good 3.0 Set-Up for This Space? r/hometheater - Good 3.0 Set-Up for This Space?](/forums/proxy.php?image=https%3A%2F%2Fpreview.redd.it%2F9cid6aqmb5c61.png%3Fwidth%3D1075%26format%3Dpng%26auto%3Dwebp%26s%3Db60a61dc0ceb460bbe08374863a6361c791dfe60&hash=9b4aa7439db168852faeb83eacbeadae)
Given the big void in the middle and top of the room, I'm worried about choosing speakers too small for the space, so I'm targeting this set-up:
- KEF Q650c Center
- 2 x KEF Q350 L/R's
- Denon AVR-S750H
A few questions:
- Is that a good AV to pair with those speakers?
- Do think I could get away with the smaller Q250c/150 set up in this space? I will be getting an RSL Speedwoofer 10 eventually, but if I go with the 650c/350's, it's a little outside the initial budget.
- I also looked at these options, would you recommend any of these over the KEF options?
- Monitor Audio Bronze C150/100's
- SVS Primes
- NHT C Center and C1's
Thanks in advance for any help!
