Hey Guys
I have a Klipsch KSW-10 Subwoofer for sale. It hasnt been used in a number of years, and still sounds great. I purchased it new for about $300. I would rate it about 7.5/10. There is one small corner where the laminate has a small crack and is not very noticeable. I will try to post pictures soon.
Perfect size for small to medium rooms!
Specifications:FREQUENCY RESPONSE 29Hz-120Hz(+-)3dB
POWER HANDLING FTC Rated Power: 55 watts continuous,
22-125Hz @ ≤ 1% THD
Dynamic Power*: 225 watts @ ≤ 1% THD
MAX ACOUSTIC OUTPUT 110dB SPL 1/8 space, 1 meter
LOW PASS CROSSOVER Continuously variable from 40-120Hz, 24dB/octave slope above 120Hz
WOOFER K-1070-K 10" (25.4cm) down-firing fiber-composite cone
AMPLIFIER Class A/B discrete MOSFET outputs
PHASE Switchable 0 or 180 degrees
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass reflex via rear-mounted port
INPUTS 2) Line level/LFE RCA phono jacks and 2) High level speaker terminals
AUTO POWER ON 2 Second ON delay, 15 minute OFF delay
DIMENSIONS 15.5" (39.37cm) x 13.5" (34.3cm) x 13.5" (34.3cm)
WEIGHT 29 lbs. (13.18kg)
FINISHES Matte-finish Black vinyl
$150 Shipped FedEx
