SLBK
I recently aquired a 5.1 TDK tremor s-80r set of PC speakers. I was told that they had been repaired a couple of times, with the fault being dodgy soldering. When I hooked then up, the speakers were clear but the sub just farted. Any suggestions as to where I look to fix it? :confused:
gmichael
gmichael
HAHAHAHAHA My old Jenson sub farts when I turn it off or it stops getting a signal. Seems to be it's way of burning off the excess energy it has stored up. I fixed mine by buying a different sub.
Sheep
Sheep
I deem this the most missleading thread title ever!
SheepStar
pzaur
pzaur
SLBK, sorry that your situation stinks!
-pat
ps - I have no helpful advice at all...
mustang_steve
If the sub farted, but the speakers still work...then it's probably a poor contact on the subwoofer driver.
If those are any bit similar to the Stereo version of the S-80, then the amp for that system is inside the subwoofer, so it either lies in the wire going to the woofer, or in the woofer itself.
Those speakers are a pain in the rump to open up. I had to service the volume pot on my old stereo S-80 set...that was unpleasant. Just be patient, and have your computer up, and document EVERY step you take to open it up....it comes in handy later if you are having trouble putting it back together, trust me on this.
Once you get it working, you will probably like them. Just make sure the subwoofer is down around your feet...it IS directional, due to the frequency limitations of NXT panels the size of the satellites on that system.
