fake bass
  • Thread starter Thread starter viseral audio
V
viseral audio
152
0
18
62
has anyone else felt bass coming from behind when it should hit you in the chest? I set up my subs near field behind seating because it smoothed out room issues and I admit they are set a little higher because I like bass that hits pretty hard. but when a kick drum hits from behind it seems strange, so I settled on one sub in front and one behind.
I think it might be that your expectations are coloring your experiences here. It would be interesting to do a blind test on this though. My guess is that the subwoofer positioning doesn't actually matter too much in this regard, but I won't say that what you are experiencing is impossible.
Presumably, "running them higher" means a higher hpf setting, so you could be getting higher, more localizable frequencies from the subs. In addition, the transient peaks of a kick drum for example are not limited to typical subwoofer frequencies but extend much higher, exacerbating localization with subs with a higher than typical hpf.
It sounds like you have the problem licked by placing one in front and one behind the listening position, which is all that matters. It goes to show how each room is it's own idiosyncratic acoustic nut to crack, particularly for bass.
FWIW, you're not the first I've heard mention something along these lines (a strong preference for forward located subs for the sake of realism-the music should come from the front, after all). Since true sub frequencies are nigh impossible to localize, I think in both yours and the other fellow's cases it concerns higher freq content (above 80 hz, up to whatever you have the subs low passed at).
Keep on rockin'.
my subs are horn loaded sound reinforcing speakers for live music, they work pretty good but they are very directional even at low frequencies because of there high output. thanks for reply.
