Running Klipsch? Even though the Big K likes to fib on their sensitivity ratings, they are still above average in sensitivity.
Considering that in any multichannel usage, Denon & Marantz claim a 70% guarantee of rated power being available to all channels. I've never fully understood this to mean that even in Multichannel Stereo when all channels are basically being driven the same... but I digress...
Considering Klipsch claims 100dB sensitivity for your Mains... lets re-rate that to a conservative 95dB.
64w @ 1m will yield a whopping and ear-bleed inducing 113dB!
If you sit 3m (~10') away in a medium sized room with some boundary reinforcement, you will still be experiencing SPLs exceeding Reference Level Dynamic Peaks!
If the 8012 is rated 2-channels at 140 w, and you get 98w per channel with their 70% guarantee, you still have a few dB headroom to utilize and completely deafen yourself with.
Do you need an Amp? Likely, no. If you really want to buy one, go ahead. However, in my opinion, all you are doing is buying unnecessary Headroom. If driven within Spec, I think all of us here tend to agree that amps will not,
AND Should Not, alter SQ.
