Hi Dn.
If you're lucky enough to have an audition with your same speakers & equipment then by all means go for it. Usually this isn't possible, so you should take some of your own cd's/movies that you know extremely well and listen to see if you hear any differences in the sound. I will give you an example:
On the Bee Gees song Got To Get A Message To You when they start singing the refrain someone is striking a triangle. Until I got the amp I NEVER heard this triangle with just the Denon driving my speakers!
I started out with the 2 channel Parasound 1500A amp, when I heard the difference that it made I just had to get an Outlaw M200 monoblock for my center channel. I now have a Sunfire 5 channel amp for ALL of my speakers. If I had known then that it would make such a big difference I would have gotten a 5 channel from the get go.
So I would say that if you have multichannel setup, then save up & get a multichannel amp of at least 200wpc & just get it done once & for all. This way you will have an amp that will stay with you not matter what other equipment or speaker upgrades you make. And it will have more than sufficient power to drive any speakers that you have now or in the future.
If you don't mind used, check out Audiogon for Rotels, Parasounds, Sunfires, etc. New, good bang for the buck is Outlaw Audio.
Don't hesitate to exercise a little patience & save more money to get what you really want, rather than rushing to get something NOW & getting less & wishing you waited to get what you really wanted.
I'm a firm believer in doing it right the first time.
dpnaugle said:
How does one audition an amp? Should you have them set it up with the same speakers and receiver if available?
For an amp I'm thinking $1000 is about my limit. Do you have any suggetions in this price range.
Integrated? 2 channel? or a surround?
thx
Dn
