External amp for fronts on marantz sr7013
Harry Dewulf
Harry Dewulf
I’m using a 5.1.4 setup on my avr, adding the atmos speakers took the dynamics away so i would like to add a amp for at least my front‘s b&w 702s2, i have never added an seperate amp so some advice would be nice :)
i’m hovering on rotel 1582 mk2 or maybe a rmb 1555 ( 5 channel), or a primare 35.2
for what i have read the marantz delivers 1.2volts output, the primare requires 2v, is that a big deal or too much research ? The lowest input sensitivity is on the 1555 at 1,5v
i’m rather skeptical vs class d primare ( in case of needed repairs), or do you think i wouldnt bother about that?
where are the experience-oholics amongst you
I’m using a 5.1.4 setup on my avr, adding the atmos speakers took the dynamics away....
Atmos/Surround speakers probably require no more than 1 Watt of power. So I don't see how Atmos speakers will take away the dynamics of anything.
isolar8001
isolar8001
Adding the Atmos speakers causes the AVR to "resteer" the output accordingly.
Sometimes this results in improved dynamics and soundstage...often it does not.
Atmos also has a much lower overall output than regular multichannel.
You have plenty of power already...adding an amp will accomplish nothing.
From what I've seen of the testing of pre-out levels of Denon/Marantz avrs, an output of 2V shouldn't be an issue. Why Rotel or Primare amps particularly?
Is there an SPL issue you are trying to fix by adding an amp?
William Lemmerhirt
William Lemmerhirt
Well to be fair, the overhead speakers in an Atmos system can be sent full range content. Now most of us are crossed at 80 or 100, but still. The potential is there.
This reminds me of @PENG telling us one time he was listening to the big KEF Blade playing loudly fullrange with McIntosh amps and the watt meter was reading “1W” most of the time.
I can’t imagine any tiny ATMOS speakers playing with more power than the giant KEF Blade.
If surround speakers were pulling full power concurrently with the mains, then All-Chamnels-Driven (ACD) would be a huge problem in the real world. But we know ACD is NOT a real problem in the real world.
Harry Dewulf
Harry Dewulf
Wow guys, one has too choose it’s words carefully and be fully declared…..
i want a better amp than my avr for the fronts, if or if not the atmos channels are the culprit. ( there is a noticeable difference between two channel and multichannel usage)
i like to listen to f*ing loud music occasionally , where i hoover between -5 and 0 db, i think my system would perform better with more performing amplification ( yes i know that 250 watts only would add 3db to 2x125watts) .
Harry Dewulf
Harry Dewulf
perception of quality , dealer in neighborhood…..
have looked to apollon hypex amps too, would really have to hear this first…
would be nice to try them all at home :)
I agree with you. I bet you are right. People here think that AVR are the ultimate Hi-Fi device when they are actually a pox on humanity, and not a sensible construct at all.
I use separates throughout on all my three systems. An AVR is never something I would put in any system I designed. I can tell you that Atmos speakers actually do take more power than suggested here. I am powering my Atmos speakers with two Quad 405-2 current dumping amps, which are highly efficient, and yet get significantly warm but not hot driving the Atmos speakers crossed at 120 Hz. Also member here think all the power in the bass, despite the fact I keep telling them they are dead wrong. Almost all the power is between 80 Hz and 2,500 Hz. Most power is required in that range. I would say the majority of speakers are actually deficient in the resources their designers allowed for that range. I design for tons of resources in that pass band. When a system is designed like that it is an absolute revelation and joy, because it reproduces music with proper dynamic and impact.
By the way, I would not worry about the reliability of good class D amps now, versus other topologies. Any failure of any amp is likely to present issues.
I just use Quad current dumpers, as I knew the designer and owner really well, and have amassed a pretty large collection of his amps. I know my way around them for service. He was a brilliant and very nice sensible chap. All his user manuals carried a clear circuit diagram, and he always published excellent service manuals for all his designs. They are all models of what service manuals should be. Unfortunately he was one of a kind. Fortunately he made huge contributions to the science and art of audio reproduction.
Perception of quality as in the aesthetics of the box or something? Haven't dealt with an audio dealer in eons myself (mostly as they just aren't where I am). What would you expect to "hear" from an amp audition?
Based on $/quality "watts", I would say the Apollon Hypex are great choices. Rotel amps typically are good looking though, to me anyway. I would stay away from the Primare amps too.
I am sure all the well known brands are equally great - ATI, Anthem, Parasound, Rotel, NAD, Bryston, McIntosh, Krell, etc.
