Extension cord for subwoofer
Patrick Kennedy
Patrick Kennedy
Is it possible to add a extension cord to a subwoofer? If yes, what kind of cord do i need? What spec?
Again thank you for the help.
ryanosaur
ryanosaur
Look for a good heavy duty cord that matches the needs of the amp
Speedskater
Speedskater
Also, try to find one that is not much longer than necessary so as to avoid coiling. :)
That's a common misunderstanding, but the only problem with coiling an AC cord is overheating if the cord is overloaded.
ryanosaur
ryanosaur
My only point was to avoid the spaghetti monster inherent in having too much cord. :D
Speedskater
Speedskater
Good point!
Actually a low end-to-end resistance of the Safety Ground wire may help lower the sub-woofer background noise.
Patrick Kennedy
Patrick Kennedy
Is it safe to plug a subwoofer directly in the electrical outlet without a power bar?
ryanosaur
ryanosaur
Pics or it didn’t happen. :p
Sent from a handheld device using a silly little app.
ScottAllenLogan
If you use a 12 gauge extension cord, it will be the same or better gauge as in your wall. No issues.
