Explanation of terms
Alex2507
Alex2507
I need stuff like this explained to me.
1 Noise floor
2 Head room
3 Leg room
4 Bottoming out
5 PEQ (can I get one for a PS-10)
That should be plenty for now. I appreciate the time and effort. Thanks.
sleeper
sleeper
Well, let's give it a try. I'm sure someone else may have better explanations for some, but let's see if I can help... :)
1. Noise floor. refers to the level of noise audible when your system is on and nothing is playing, or the noise inbetween songs, or the recording itself during a quiet passage.
2. Head room. refers to having "a little extra in reserve". Sometimes used in reference to wattage, but not exclusively.
3. Leg room. umm... not really sure, but may be similar to number 2. Or how much room your back seat passengers have to stretch out their legs? :confused:
4. Bottoming out. usually in reference to a speaker achieving its maximum extension and audibly distorting.
5. PEQ. Parametric equalizer. A type of eq where the user can select the frequency to adjust and how "thick" to make it. (also known as the "q"; basically how much of the adjoining frequencies will be affected.)
I hope that helps somewhat... and hopefully I'm correct on what I've written.
sleeper
Oh, and if your sub doesn't have a PEQ, you can run one, or any other form of equalization, inline from your receiver to the sub.
Alex2507
Alex2507
Ohhh....
Maybe I was suppose to put question #3 in the truck forum:rolleyes:
What an eye opener. I didn't think my system made any noise when it wasn't suppose to. I'll be sniffing around the speakers durring those quiet passages telling the girl that the noise floor is marvelous. :D
markw
Either that, or you're thinking of a blonde joke. PM me for more info.
