If i set my main speakers for 100 hz will that cutoff frequency below 100 hz or above 100 hz, please explain how it works.
Dan, wow! You asked a very simple question and got a quite technical and detailed answer. Don't be discouraged. I'll bet MOST people could not follow or understand all that.
shadyJ gave you a good answer.
First, you say, "set my main speakers to 100hz". By that, I'm guessing you refer to "Crossover". That is a setting you can control in most AVRs. It is for people that have a separate subwoofer, (or 2, 3, 4.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
A subwoofer is a speaker designed to produce ONLY the low frequencies. These are the low frequencies of thunder, explosions, monster foot stomps, and very low bass in some music. No "bookshelf" speakers can reproduce those frequencies, and many "tower" speakers can't either. You have to get into pretty expensive tower speakers, (several thousand $), to accurately give you those lows. And even those likely can't do the thunder and monsters very well.
Also, movies have a separate channel just for the lowest of the lows. It's called the LFE channel, (Low Frequency Effects). The LFE channel is the ".1" in a 5.1 or 7.1 soundtrack. It doesn't exist in music, only movies & TV. So a lot of people get subwoofers.
But now you have a speaker, (subwoofer), designed only for very low frequencies, and you have to tell your receiver where to split the signal between your regular speakers and subwoofer... thus the "crossover". It is the point you're telling your receiver to send signals
above that freq to your regular speakers, and
below that freq to your subwoofer(s). Depending on the capability of both your speakers and your sub(s), you can set this crossover at the point that best matches your equipment. Usually people set it around 80Hz.
You got some detailed explanations about how the crossover is not a sharp cutoff, but a rolloff. True, but from the nature of your question I'm guessing it's something you don't really need to worry about.
If you have more questions, please feel free to ask. Don't worry. Sometimes we get carried away w/ tech talk, but we'll always come back and answer your question in plain English.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
