Wattage
Also remember power is logrithmic.
Sound is normally measured in deciblels= dB
whisper = 30 dB
normal voice = 60-70db
level at which substained exposure may result in hearing loss = 90-95dB
very loud rock concert 115dB
loudest sound possible - 194 dB
Decibels express a power ratio, not an amount. They tell how many times more (positive dB) or less (negative dB) but not how much in absolute terms. Decibels are logarithmic, not linear. For example, 20 dB is not twice the power ratio of 10 dB.
The defining equation for decibels is
A = 10*log10(P2/P1) (dB)
Commonly used dB values
dB level powerratio dB level voltage ratio
−30 dB 1/1000 = 0.001 −30 dB = 0.03162
−20 dB 1/100 = 0.01 −20 dB = 0.1
−10 dB 1/10 = 0.1 −10 dB = 0.3162
−3 dB 1/2 = 0.5 (approx.) −3 dB = 0.7071
3 dB 2 (approx.) 3 dB = 1.414
10 dB 10 10 dB = 3.162
20 dB 100 20 dB = 10
30 dB 1000 30 dB = 31.62
You AVR Onkyo is very nice receiver at 100watts per channel and your speakers are 8 ohm and 91 dB sensitivity ( a little better than average) you should be able to drive your speakers to a very nice level, probably a lot louder than you want
