I have seen some espresso/coffee threads on here in the past so I figured maybe someone would have some knowledge on this subject.
I have had my Saeco Easy super automatic machine for about two and a half years and it has been trouble free until a couple weeks ago.
Problem: It grinds, tamps, and the pump makes noise like it's pumping water but no coffee comes out. The grounds go on to be dumped bone dry and instead of falling in the form of a neat puck into the dregs container, they go all over the place inside the machine. So, the water doesn't appear to be getting to the coffee. It also isn't spewing out into the machine or onto the floor. I know the pump works because I can get hot water and steam out of the wand. Any ideas?
There is something that I am quite embarrassed to admit. I have never descaled the machine. I have very soft tap water but I can't explain why I have never gotten around to descaling the machine but I haven't. I don't even know where to fine descaling solution. Could this be the problem?
Hey HiHo, my machine is taken apart right now too, a Saeco. Blasted superautomatics. Been drinking french press for a little while now. I've also never descaled. I figure I would if the espresso wasn't ever flowing freely enough.
I'd try calling for support/tips. I called where I bought mine from, and we figured it's probably a grinder issue (it would grind, but nothing comes out at all, and I mean nothing). They emailed me an instruction list they had to clean the grinder out (figuring beans ain't falling thru). I did, still have issue. I have yet to call back, to see if I can get better advice.
Really though, I'm waiting to see when my engineer (super brains) is in town again, as he can fix anything.
He's already fixed a different espresso machine, surfboard, anything.
I LOVED having a superautomatic, and so did anyone that was visiting. It's supplied a lot of coffee love, and after thousands of espressos, I guess the overall cost was still worth it. But, there seem to be too many things to go wrong, at least when buying the cheapest entry level, which is what I did. Sorry, I can't help much. Try calling, you never know if they might have the magic trick... or maybe a replacement part that's not expensive.
