Hello,
So im planning to build a pair of bookshelf MTMs, with good sound and a great kick. I was recomended these two speakers, and they really seem great, especially the ER18s have a lot of satisfied users, but so does the DXT.
It is also worth mentioning that i live in norway, and i have yet not found any resellers with the Dayton or Fountek tweeters used in Dennis Murphy and Paul Kittingers ER18 build.
Before replying to any of the questions below, please note that this is my first DIY project, and though ive tried to read up as good as possible (through loudspeaker cookbook etc.), not everything is explained as clear.
I have X-over 3 Pro, so i decided to try to set up the xo, and set it all up as 3rd-Order Butterworth, because if i am not mistaken, MTMs with odd-order Butterworth are good (due to a reason that dissapeared from my mind as i was typing it). The problem is that i get a peak at the LP xo frequency no matter what.
Second i was curious about driver sensitivity, x-over3 displays that the two woofers sum up to a sensitivity total of 94,5dB and the tweeter has 92dB would this be an issue?
Third i was curious if i have to worry about impedance differences when calculating the crossover values in x-over3.
Also, i have been told that its worth getting xo components that are decent, with a build like this, in this pricerange, what xo components would you pick?
Thanks for your time, correct me if ive said something weird! Im also open to suggestions if you have other speakers that would fit my description.
