Hi there,
As some of you already know, I've posted quite a few graphs using my new SMS-1. The response is really flat IMO.
It makes sense to think that if one cuts certain frequencies that that would equate to more headroom at higher levels. If I toggle between preset 6 (no eq) there is about a 4-5 dB greater output from 20 hz to 40 hz.
My reasoning is that if I equalize flat that when playing film material at reference level, I'll have more headroom and less output compression. I have an SVS PB10 ISD in a 3000 cubic foot room. The subwoofer is positioned 2.6 meters away from me (I recently moved it).
Playing back any material at reference yields no infrasonic impact whatsoever. I tried the Matrix Revolutions end fight in the street and the slo-motion lightning has no felt impact. Switching to preset 6, there is quite a bit more deep bass.
My problem is that my subwoofer is obviously not capable of pressurizing a 3000 foot cubic space at reference level. What bothers me most is that if I take my EQ'ed result and increase my calibrated sub level from 73-74 dB's to 77-78 dB's that there is considerable more low end that is felt, which means that my subwoofer is then, theoretically, capable of 124-125 dB's at the listening positon.
That's just impossible.
It's not as if it's not to be expected that increasing the sub level will also increase my chances of having more pressurizing bass, but the demands placed on my subwoofer should be far greater and, if anything, I should be experiencing less bass, not more at reference as my subwoofer is notorious from suffering from output compression.
I would have expected reference level bass to be something considerably more powerful than what I am experiencing with a single PB10. I've tried several films. I popped in The Incredibles. I tried Chapter 23. Bass is alright at reference. But there seems to be more "gas" left in the tank so to speak. This is what I don't understand. My sub shouldn't have more headroom at these levels (especially when there is no felt impact at all).
Reference level is supposed to be around 115 dB's and I've set my speakers to small, 80hz crossover so then reference level will equate to 121 dB's. But why is it that my subwoofer can be set to even higher levels and provide more impact especially at reference level (calibrated to 75 dB's for the main's, MV set to 0) ?
Has anyone Eq'ed their frequency response flat from 20 hz to 80 hz, calibrated their subwoofer flat with their main speakers and still experienced bass that they can feel ? Because I'm finding that I can't. It's almost as if I should be experiencing a lot more bass at reference level.
Heck, most people can't even play their subwoofers at reference level for fear of over excursion or thermal compression. In my case, at reference, bass sounds, in a word "blah". Have I done something wrong in my setup ?
I've even considered perhaps purchasing a better subwoofer (an Epik Valor or an additional PB10 ISD) thinking that maybe I don't have enough woof for the room. But then that is thrown out the window when I calibrate at much higher levels and I still experience far higher, pressurizing bass at the listening positoin.
Thoughts and suggestions would be appreciated.
PS Sorry for the long post !
--Regards,
