EQ of Yamaha RX-V2500 receiver
alpharetta
Dear Bros,
I have stupid question... How to access to EQ feature of Yammy 2500? Example if I want to boost 50 hz a little bit, what step I should do with the receiver?
Thanks and Happy holidays
Alpharetta
G
gcmarshall
if you have your receiver hooked to your TV such that you can use its onscreen GUI, then you can go into the EQ settings that way. it's very easy to get there via the menu options, but since i don't have my system in front of me right now, i can't give you the exact steps. go into the GUI once it's up on your TV screen and play around with the submenus and you will likely find it easily.
F
fergusonv
I have been looking into getting a 2500 and from what I've read the lowest it will eq is around 62hz. Yamaha has the manual for the 2500 on the web if you don't have yours.
