Then don't worry about it. Regardless, I disagree with lsiberian's blanket statement. It starts becoming imperative to treat the back wall when you are right up against it, or are very close to it; the places to treat can really vary from setup to setup.
Doug (strongbadf1) probably gave you the best advice yet. Have her pick it out. nibhaz has recommended this method as well.
You can try a DIY kit, and use dye to make your art, if you are so inclined.
http://www.readyacoustics.com/index.php?main_page=index&cPath=26_11
You can also send a pic of choice to GIK for their custom printed panels, though the price gets steep. Here are pics of Glenn's own panels, for instance:
http://forums.audioholics.com/forums/showthread.php?t=52332
Finally, and I know you said the FR is very good from the subs already, but if it was easy enough to accommodate, I'd still aim to treat below 80hz if it was easy enough there. Just me.
