hi there
just be sure we are talking about the same thing, this system is in a car, ther head unit is the radio, im not sure what the amps are, i dont know what sub out are, all i can tell you is each amp as you will know, has connections for the speakers, what are the front rea sub outs, hear in the UK ive not heard of that before. i havent managed to get the resistance reading of yiour last suggestion yet.
but what im confused about is the two rsa's from the back of the radio are left and riight channel, i assume that is for stereo, so why can i split them as i have with my config, surely the two channels shoulkd follow each other.
on the 1000w amp there is four channels, 1/2 on the left 3/4 on the right, while it is working as you said, should not the two rca's from the radio go to either 1/2 or 3/4 not 1/4 or 2/3 this splitting seems odd, but as you say it works.
what i fail to undertsnd is if i slpit the two rca leads ont to one amp and one to the other, i end up with right channel to one and left channel to the other, so how can i then split the cable the formm a left and right channel, when all i strted with was a right channel only.
god this is confusing
thanks for your help youve been great.
charlie
