Hi Guys,
I am new to this forum and posted one question before about getting a receiver which until now i am convinced to get a pioneer elite sc-05.
Now for the speakers i have my eye on two possibilities (after making a good research and taking my space options in my living room and budget into consideration):
option 1: the energy take classic 5 pack with two possible subwoofers which are the s10.3 or the ESW-V8 (
if you can advise which is better it would be good because i am somehow limited by the weight as i am taking it back by plane to my country?.
option 2: The energy take micro 5.1 since they have smaller size and more powerfull sattelites as i have heard.
Now my room is around 16x15 feet and 10 feet high ceiling, this is the room that should be covered by the surround sound, but it is not an enclosed room, i.e. it has one full open side to a wider area that is double the size i am talking about, but the sounds seems to be pretty contained inside the area i mentioned above without loosing its energy to the open area.
I will position the rear sattelites directly on the wall behind my ears and at somehow ear level due to aesthetics concerns (i.e. on a line 20 cm parallelto where i am sitting but on the sides of my ears, dont worry a 1.5 meter far from each ear
i am concerned with the following two main things in regards of choosing amongst the above options:
One: if i get the energy take classic, the sattellites are somehow a little large to put on brackets on the wall, so most probably i will have to flush mount them on the wall behind me and thus cannot direct them towards my ear or middle of the listening area, they will be pointing in the same direction as my head towards the 40 inch HDTV.
two: if i get the energy take micro, i would be able to put them with brackets and direct them with an angle towards the listening area, they are of higher power then the classic, but the woofer is less powerfull then the ones i am thinking of with the energy take classic.
Sorry for the long description,
but which option should i go with? (if it may help, i like watching blue rays and DVDs more then listening to music (I still like music from time to time), and i might not always be able to listen to full power of the speakers due to the neighbors especially that i watch movies at night.
Your opinions and suggestions are highly appreciated.
