Energy Take Classic VS. Infinity TSS-1200
nickburnsaudio
nickburnsaudio
Looking for a 5.1 home theater speaker set and have narrowed it down to these two. I'm new to the game, so which one is the better buy?
zieglj01
zieglj01
What steps did you take to narrow this down?
shadyJ
Speaker of the House
Staff member
Between those system I would definitely go with the Infinity system. Looks like it has a better sub, and more woofers on the satellites might give it some desperately needed extra bass given how small the speakers are. Also it looks to have a more formidable center channel speaker.
nickburnsaudio
nickburnsaudio
I should have clarified this to begin with!
Well, my original budget was below $500. The Energy speakers had the best reviews I could find for the price. I have a modest size living room. A friend recommended the Infinity speakers on clearance at $449 at Newegg which seemed like a good deal, but they were sold out by the time I got to them. The cheapest I can find them now is $795 online...is it worth paying almost double for the Infinity speakers?
3db
3db
I would audition both to see which you like better. The satelites on the Energy despite having a 0.5" smaller driver than the Infinities play lower than the Infinities which would mean easier integration with the sub and maybe less localization of the sub. The Infinitiy has a better sub being able to play lower than the Energy.
There is no clear winner in this comparison. Its up to what your ears tell you. :)
shadyJ
Staff member
At 795, you can do better than any home-theater-in-a-box. In that range, look at getting some Behringer 2030p studio monitors or some Infinity Primus p152 bookshelf speakers. A set of 5 of either should run you less than 400. Then look for used or reconditioned receivers for around 200. Check out Accessories4less.com for some options here, or ebay. For a sub, I would look at a cheap BIC or Dayton 120. A system like that would walk all over the Infinity while costing the same.
If that is too much for you, check out the Hsu Performance 1 or 2 package from hsuresearch.com, that might be better than the Energy Take system, looks like the Hsu system has a better subwoofer and better center channel for not a whole lot more money.
zieglj01
zieglj01
If you already have a receiver - then go to www.ac4l.com or Amazon
and look at the KEF kht2005.3 speaker system. Their sub/sat systems
sound good.
