CraigV
CraigV
Emotiva XPA-5 review
I have had some time now to spend with my XPA-5 and explore it’s merits vs. the B&K Sonata Video 5 it replaced, as well as an average AVR receiver.
But first, a word on the theory of the audio chain. Unless you’re a musician who has the ability to record, we all find ourselves coming in at the middle of the chain - the material has been recorded, edited, mixed, engineered & marketed in convenient disc form. The equipment we choose to buy is then responsible for reproducing the sounds/music in our homes, while (ideally) being faithful to the sounds/music on the disc.
Typically the end of the chain involves: 1. A disc player (turntable, CD player, DVD/BD player - with or without D/A converter) 2. A pre-amp which may convert digital to analog, as well as process surround sound formats, add tone & volume control 3. An amplifier or 4. A receiver which combines 2 & 3. 5. Cable to go from the pre-amp to the amplifier & from the amp to the speakers, and finally 6. The speakers.
As we all know, “a chain is only as good as its weakest link”. Since we have no control over what happens to the sound being put on the disc, we are left with the end of the chain. The most common item people consider is speaker cable. Small gage wire isn’t very conducive to transmitting the signal to the speaker in the best manner. Like most “upgrades”, there are practical concerns, and ridiculous ones. There are some merits to specialty speaker cables, but only to a point. Investing a reasonable amount of money will add sonic benefits, but only if the rest of the links in the chain are up to snuff. A mediocre receiver & speaker will not be made to sound great with expensive speaker cable. As such, introducing such a change may not have a noticeable impact, but may have a subtle one. As each link is “upgraded”, each will add another subtle change, which when added together can make an appreciable difference, even to the casual listener. This is why I have the equipment, or “links” that I do. No one is going to make a night-and-day difference in what I hear, but accumulative effect is they come together to make a very good sounding system.
Some members here have realized the benefits of simply adding an outboard amplifier to an existing system. The Emotiva line of amplifiers offers the HT and music enthusiast the opportunity to reap the benefits of such an upgrade without being priced out of reach. This also allows the end user to only upgrade the pre/pro as newer technology becomes available while keeping the amplifier. I have chosen to go the route of separates for the added, albeit subtle difference in sound quality.
Wit the B&K amp, I was getting very good sound. I would categorize the sound as “warm”. Many people ask what makes one amplifier “warmer” than another. As near as I can tell, it means a somewhat recessed treble response. More to some peoples liking than others, it usually is a characteristic favored for music reproduction than movies. Music sounded very good, but movies seemed to be lacking a bit of impact.
I should mention that the system is in the upper floor of a split level house. The right speaker has the normal room boundaries, but the left has no wall near it. As a result, some of the bass energy from the speakers & subwoofer is lost. I knew adding power to the output of the amplifier would help, so I did a lot of research, considered used vs. new and found a good offer on a slightly used Emotiva XPA-5. My other consideration was a Sunfire Cinema Grand, but the Emotiva had some great reviews and was about $250 cheaper, both amps being on the used market.
In terms of tonality, the Emotiva was not as warm as the B&K, which I take as it being more neutral. The soundstage was very much the same - wide, deep & tall. Where the Emotiva had a clear edge was in focus. I use two KEF IQ7 speakers as my front end, in a “phantom center” configuration, where the center image is blended equally into the two front mains. I prefer this arrangement as the focus stays on screen, and pans are more cohesive. Switching from a conventional “tweeter on top” two way speaker to the KEF coincidental configuration helped to broaden the “sweet spot” but the addition of the Emotiva amplifier helped to solidify the image even more. We have a wide couch at the opposite end of the room, and the sweet spot is now the whole width of the sofa. Another way to look at it is this - by upgrading the amplifier, I have negated the need to buy a matching center channel speaker at a cost of $500, which when deducted from the price of the amp makes it a phenomenal value.
The next area the Emotiva helped in is the bass. Watching scenes from Transformers, Iron Man & The Dark Night (all on BD) brought about a whole new level of percussion & concussion that were missing before, particularly in the areas of gun shots & explosions. Since the level of my subwoofers were matched to that of the main speakers, I knew I was hearing the woofers on the IQ7’s really kicking. However, I never got the sense that the bass was being overdone, it was just more present than before, which is how it is encoded onto the disc.
Another advantage was in the level of detail. Subtleties in the wavering of voices which were not readily apparent before were present. Again, the amp wasn’t artificially adding something that wasn’t in the mix, but rather revealing what had been there all along. Very satisfying indeed.
As for music, aside from the slightly (and I do mean slightly) brighter presentation, all the other sonic benefits that added to movie listening are present in musical reproduction. Tighter focus, detail, bass response, neutral tonality…while I find I prefer a slightly warm presentation to my music, as this system is used for both music & movies, the trade off is so slight that I don’t feel like I’m missing out on anything.
As for most any of us, I know there is better equipment out there, but unfortunately in order for us to enjoy any of it would mean having to pay enormously inflated prices associated with these “premiere” brands, which means helping to perpetuate the misnomer that you have to spend mega $ to own a certain label. There are many quality products all throughout the chain that can be had for a reasonable amount of your hard earned cash from companies that know you want a quality system, but that you also live in the real world, with real income & expenses. Emotiva is one such company and very worthy of consideration from anyone looking for a real world upgrade to their system. I whole heartily recommend this amplifier to anyone looking to reap the benefits from a quality external amplifier.
Associated equipment:
Panasonic BD55 Blu-ray player (using internal decoder & D/A converter for music & movies)
Rotel RSP-1066 pre-pro
KEF IQ7 front main & IQ8DS surround speakers
Audioquest interconnect & speaker cables
Parts Express speaker cable
Klipsch KSW12 subwoofer
Belkin power conditioner (amplifier plugged into separate wall outlet)
cfrizz
Very nice review, and pretty much right on the money in describing the benefits of adding a beefy amp to one's gear.
Isn't it amazing to hear what your speakers are TRULY capable of sounding like when they have all the power they need to play clearly what's already there, but you never heard it before.
Congrats & enjoy!
walter duque
walter duque
Very nice revue. There is nothing like a good poweramp, especially for that price. There is good equipment outthere without having to spend a small fortune.
sawzalot
sawzalot
I like this review alot it just makes sense,I also have the Emo XPA-5 and clearly just dont feel the need for the center either I setup in phantom mode.I find myself thinking that I should have bought an XPA-2 instead cause I just might not use the 5 to its fullest.Maybe I should run the rear and or surround through the amp also ,How are you using your options to the fullest.
CraigV
CraigV
Two IQ7’s in the front and 2 IQ8DS in the rear. According to the Emotiva web site, this results in a full 230 watts to each 8 ohm channel.
cfrizz
If you have 5 speakers, then you should be utilizing the amp for all 5 channels.
I will never understand why everyone insists that the back speakers don't need or won't sound better with extra amplification.
That doesn't make any sense. Just like the fronts they will take all the power they need when they need it to sound their best.
I had a 2 channel Parasound & an Outlaw monoblock for my center & let my Denon handle the back. I noticed just as big an improvement for my rears when I got my 5 channel Sunfire.
So stop cheating your poor rears speakers out of the power that they could also enjoy & amp them up.:D
Oh 1 more thing. It's not about utilizing the amp to the fullest, it's about making sure the SPEAKERS have all the power they need to be utilized to their fullest!
CraigV
CraigV
Indeed - I was concentrating so much on what was coming out of the front, I didn’t take into consideration that the rears were keeping pace because they were being fed the same quality amplification.
The overall presence of all the sound is better off with all the speakers equally engaged.
adk highlander
adk highlander
Sith Lord
Thanks for the right up Craig. I too have found the benefit of moving to an external amp that offers well more SPL's than my room can handle.
I'm not sure I go with your phantom center theory but if it works for you I will not doubt you.
jwenthold99
jwenthold99
Thanks for the review! I am thinking about getting the UPA-7 sometime in the future, so it's nice to read good things about the company.
croseiv
croseiv
How'd I miss this?? Thanks for the review there! I have just ordered a XPA-5 myself as an upgrade over the amp section of my VSX-1015TX. This review has made me glad I picked the XPA-5.
selkec
selkec
I also have the XPA-5. Anyone planning on getting it will be very happy. I also had the xpa3. Both amps are awesome.
G
greggp2
I have an XPA-2 and ordered an XPA-5, B-stock. The B-stock came in defective and Emotiva immediately set up a call tag pick up and refunded my money. They are a pleasure to deal with and I'm very happy with my XPA-2. Once they release their XMC-1 I will likely purchase the XPA-5 again for my surrounds. Nice review Craig, I think for the money, this company is tough to beat!
Ron Temple
Nice review Craig. I haven't heard the Emo amps and I'm more of a warm guy myself, but there's nothing like dynamic, neutral or warm, to put a smile on your face. I'm glad you discussed synergy in the chain. It's what makes us tweakers tweak.
mesojdm
what was defective on it?? I got a good deal on a Bstock as well...but its still sitting in the box, I hope it works!:eek:
captiankirk28
Nice review thank you! I also really like my XPA-3 i now have enough SPL to fill my room and than some, very nice and hard to beat for the money.
sedonalar
xpa-5 Bravo!
Good review Craig V. of the XPA-5. I have been on the fence regarding an ext amp such as the XPA-5, Outlaw, or Parasound unit. The Emotiva really does seem to have a nice balance of power and price. I have been debating feeding my Mirage om-9's, center OM-c2 with a Onkyo 876, 906, or Yamaha ZX7. For the money of the XPA-5, I feel I could save $$ and always have power on reserve, while being able to upgrade the head unit, (AVR) when the latest DAC's & connection upgrades arrive, HDMI 1.3a, 1.4, who knows in the future etc.
Any thoughts on a good matching AVR that would blend well (pre-outs) with the Emotiva. Between Onkyo, Yamaha, Pioneer, Denon?. Do any of these AVR's have better pre-outs or signal paths that would work better with the Emotiva? I run two subs, Mirage S12 and Mirage OMD Prestige 10 in a large room. I have thought of any of the new AVR's with two sub pre-outs. Does the Emotiva get hot like the Onkyo's or the Yamaha ZX7??? Will I need a fan in a console with the Emotiva XPA-5?
CraigV
CraigV
Any amplifier is going to need ventilation, but I’ve never had a problem with heat from mine. Also, go to their web site & get the dimensions - it’s a beast. As for receivers, you would do better with a pre-amp, but to get one with all the latest features would be very expensive. If you do go with a receiver, since the amp will be powering your speakers don’t feel like you need to get the beefier receiver. Get the least expensive model that offers pre-outs and gives you the latest surround decoding.
Another option (which is what I do) is buy an older used pre-amp & a Blu-Ray player, like the Panasonic BD80 which decodes everything internally and outputs via RCA analog which you then plug into the pre-amp. This will give you better sound quality than a receiver and still allow for all the surround sound codecs.
