Emotiva Stealth DC-1 - Both Outputs At Once?
3
3Point
Hey all. First post here as I'm generally pretty good at doing my share of research without being much of a bother. This is one I can't seem to find the answer to though...
Can you use the balanced and unbalanced outputs at the same time? I'll have to start looking elsewhere if the answer to this question is a solid negatory. Will be running a pair of powered monitors and a subwoofer or an amp and a sub so I really do require both outputs to be simultaneously active. Not a fan of splitters...
Thanks for your input.
WaynePflughaupt
WaynePflughaupt
Don’t see why not. Hook it all up and see.
Regards,
Wayne A. Pflughaupt
Most avrs and pre's I've heard of the pre outs would be active full time...
3
3Point
I don't have one here to try. Looking for something to fit the bill in my office without breaking the bank. Just don't know if each output is individually selected in the menu system or if both are running full time.
I'd say full time. The downloaded manual or a call to them....
