MPS-2 Mini-Review
It's just so pretty. I'd prefer the 5 but they are both the same size, and absolutely beautiful. Hows it sound?
Well, I'm glad you ask because here is my little review:
MPS-2 Review
Build Quality
Weighing almost 118 pounds, the MPS-2 is built like a tank. It feels like a tank too. Everything is tight and sturdy as can be. Nothing feels loose. I feel like this amplifier is extremely well built.
Fit & Finish
Everything fits together very well. I had to slightly push 2 of the modules a hair to the left to get the screw holes to line up for the screws insertion, but it was not a difficult task. The back of the modules are not completely flushed with the back of the amplifier, but they are all even with each other. Overall, the fit and finish is excellent.
Installation
After unpacking the 3 boxes and un-wrapping the 7 power modules and 1 chassis, it was time to assemble the unit and installing it into my audio rack. The careful and diligent process took about 2 hrs and this truly increases the “bonding” between the MPS-2 and me. I could have completely the assembly of the unit in less than an hour, but I wanted to be extremely cautious and thorough. Everything had to be done 100% correctly, because I sure did not want to have to redo anything afterwards! For example, each of the thin plastic film that covers the 7 power modules front electrical had to be removed or the amp will not work. I was determined not to make this mistake!
I first placed the 33 lbs chassis on my audio rack. Just the chassis alone weighs as much as some fully assembled amplifiers! There was no way I could have placed a fully assembled 118 lbs MPS-2 on my audio rack all by myself (each module weighs 12.125 lbs). Then I glided each module into its cage one by one and inserted the 4 screws for each module. That’s 28 total screws for all 7 modules. Afterwards I felt pretty proud of myself.
I connected the MPS-2 to my 3 ACURUS RL-11 preamps and my Definitive BP7000SCs mains, CLR3000 center, and BP7001SC surrounds.
Listening Test
So how does the MPS-2 sound? One word: Neutral. It sounds exactly like the way all great amplifiers should sound - neutral. It does not add or subtract any flavors of its own. It does not sound warm or cold or sweet or sour. The MPS-2 just delivers (200 WPC into 8 ohms, 300 WPC into 4 ohms, and 400 WPC into 2 ohms). The sound of music and soundtracks were unaltered. Rock music, Alternative music, Pop music, Classical music, loud action movies, and softer dramas all sounded great. And afterwards, the MPS-2 was still one cool daddy, literally. It never got hot playing several hours of 90 dB-C music and movies.
